一般您可以在以下位置找到设备的序列号(SN):
Generally, you can find the device's Serial Number (SN) in the following locations:
- 产品包装盒或设备本体上的标签贴纸
- Label stickers on the product packaging box or the device body
- 将设备连接至软件后,在设备信息页查看
- After connecting the device to the software, view it on the device information page
具体的教程您可以点击对应的产品进行查询
You can click on the corresponding product to query the specific tutorial
Seestar Series
查找方法(不同型号查找SN方式相似)
Search method (the way to search for SN is similar for different models)
- 外包装箱
- Outer Packaging Box
1)牛皮纸箱侧面的贴纸中可找到产品SN或者WIFI名称后缀
1) The product SN or the Wi-Fi name suffix can be found on the sticker on the side of the cardboard box.
2)彩色BOX侧面的贴纸中可找到产品SN或者WIFI名称后缀
2) The product SN or the Wi-Fi name suffix can be found on the sticker on the side of the color box.
- 本体
- Body
产品本体底部的贴纸中可找到WIFI名称后缀
The Wi-Fi name suffix can be found on the sticker at the bottom of the product.
- 软件
- Software
设备开机并在Seestar APP内连接后,在设备信息中可找到WIFI名称后8位
After the device is powered on and connected within the Seestar APP, the last 8 digits of the WIFI name can be found in Device Information
外箱/BOX
本体/Body
Seestar APP
Camera Seires
无线智能相机 | Wireless Smart Camera
- 外包装箱
彩色BOX的侧面或底部贴纸中可找到产品SN
The product SN can be found in the sticker on the side or bottom of the colored BOX
- 本体
- Body
产品本体贴纸中可找到SN(WIFI名称后8位)
The SN (last 8 digits of the WIFI name) can be found on the product body sticker
- 软件
- Software
相机通电后连接至电脑,并打开ASIStudio,在相机信息中可找到SN
After the camera is powered on, connect it to the computer, open ASIStudio, and the SN can be found in the camera information
外箱/BOX
本体/Body
ASIStudio
深空相机 | Deep Space Camera
- 外包装箱
- Outer Packing Box
- 软件
- Software
相机通电后连接到电脑,并打开ASIStudio,在相机信息中可找到SN
After the camera is powered on, connect it to the computer and open ASIStudio , and the SN can be found in the camera information
外箱/BOX
Outer Box/BOX
ASIStudio
行星相机 | Planetary Camera
- 外包装箱
- Outer Packing Box
- 软件
- Software
相机连接到电脑,并打开ASIStudio,在相机信息中可找到SN
Connect the camera to the computer and open ASIStudio , and the SN can be found in the camera information
外箱/BOX
ASIStudio
导星相机 | Guide Star Camera
- 外包装箱
- Outer Packing Box
- 软件
- Software
Connect the camera to the computer and open ASIStudio, and the SN can be found in the camera information
外箱/BOX
ASIStudio
ASIAIR Series
- 外包装箱
- Outer Packing Box
彩色BOX底部贴纸中可找到产品SN
The product SN can be found in the sticker on the bottom of the colored BOX
- 本体
- Body
产品本体贴纸上可找到SN(WIFI名称后8位)
The SN (last 8 digits of the WIFI name) can be found on the sticker of the product body
- 软件
- Software
设备开机并在ASIAIR APP内连接后,可看到设备SN(WIFI名称后8位)
After the device is powered on and connected within the ASIAIR APP, the device SN (last 8 digits of the WIFI name) can be seen.
外箱/BOX
本体/Body
ASIAIR APP
ASIMount Series
- 外包装箱
- Outer Packing Box
彩色BOX的侧面贴纸中可找到产品SN
The product SN can be found in the sticker on the side of the colored BOX
- 软件
- Software
1)赤道仪通电后连接到电脑,打开ASIStudio,在赤道仪信息中可找到SN
1) After powering on the equatorial mount, connect it to the computer and open ASIStudio, where the SN can be found in the equatorial mount information
2)赤道仪通电后连接到ASIAIR设备,打开ASIAIR APP,可找到设备SN
2) After powering on the mount, connect it to the ASIAIR device, open the ASIAIR APP, and you can find the device SN
外箱/BOX
ASIAStudio
ASIAIR APP
CAA
- 外包装箱
- Outer Packing Box
彩色BOX的侧面贴纸中可找到产品SN
- 软件
- Software
CAA连接到ASIAIR设备,打开ASIAIR APP,在CAA信息中可找到设备SN
CAA connects to ASIAIR device, open ASIAIR APP , and the device SN can be found in CAA information
外箱
Outer Box
ASIAIR APP
EAF Series
- 外包装箱
- Outer Packing Box
彩色BOX的侧面贴纸中可找到产品SN
- 软件
- Software
EAF连接到ASIAIR设备,打开ASIAIR APP,在EAF信息中可找到设备SN
EAF connects to ASIAIR device, open ASIAIR APP, and the device SN can be found in the EAF information
外箱/BOX
Outer Box/BOX
EFW Series
- 外包装箱
- Outer Packing Box
彩色BOX的侧面贴纸中可找到产品SN
- 软件
- Software
EFW连接到电脑,并打开ASIStudio,在EFW信息中可找到SN
Connect the EFW to the computer and open ASIStudio, and you can find the SN in the EFW information
外箱/BOX
ASIStudio
Telescopes Series
在镜头内圈找到SN
Find the SN within the inner circle of the lens
