Seestar Smart Telescopes — Which to buy(在售机型怎么选)
This article helps you choose between the currently available Seestar smart telescopes: S50 Pro and S30 Pro.
本文用于帮助客户在当前在售的 Seestar 智能望远镜中做选择:S50 Pro 与 S30 Pro。
Available models(在售机型)
| Item | S50 Pro | S30 Pro | S30 | S50 |
| Status(状态) | Available(在售) | Available(在售) | Discontinued(已下架) | Discontinued(已下架) |
| Lens system(镜头结构) | Dual: Tele 50mm + Wide (4K) | Dual: Tele 30mm + Wide (4K) | Dual: Tele 30mm + Wide | Single: 50mm |
| Aperture(口径) | Tele 50mm / Wide 3.4mm | Tele 30mm / Wide 3.4mm | Tele 30mm / Wide 4.13mm | 50mm |
| Sensor(传感器) | Tele 1/1.2" 2.9µm (8.3MP) / Wide 1/2" 1.6µm (8.3MP) | Tele IMX585 (1/1.2" 8.3MP) / Wide IMX586 (1/2" 8.3MP) | Tele IMX662 / Wide (wide-angle sensor) | IMX462 (1/2.8" 2MP), no wide-angle |
| Resolution(分辨率) | Tele 2160×3840 / Wide 2160×3840 (4K) | Tele 2160×3840 / Wide 2160×3840 (4K) | Tele 1080×1920 / Wide 1920×1080 | 1080×1920 |
| Field of View(视场) | Tele 2.8° / Wide 63° | Tele 4.6° / Wide 63° | Tele 2.46° / Wide 23.2° | 1.46° |
| Focal Length(焦距) | Tele 260mm / Wide 6mm | Tele 160mm / Wide 6mm | Tele 150mm / Wide 14mm | 250mm |
| Optical lens(光学) | 4-element APO + ED | 4-element APO + ED | 3-element APO + ED glass | 3-element APO + ED glass |
| Battery(电池) | 10000mAh (up to 9h) | 6000mAh (6h) | 6000mAh (6h) | 6000mAh (6h) |
| Storage(存储) | 128GB eMMC (~100GB usable) | 128GB eMMC | 64GB eMMC | 64GB eMMC |
| Net weight(净重) | 2.8kg (main unit) | 1.65kg | 1.65kg | 2.5kg |
| Size(尺寸) | 140×149×268mm (folded) | 140×80×210mm | 210×140×80mm | 142.5×130×257mm |
| Milky Way star-trail shooting(银河星轨拍摄) | Supported(支持) | Supported(支持) | — | Not supported(不支持) |
| NFC | Supported(支持) | Supported(支持) | — | Not supported(不支持) |
| Min. working distance(最近对焦) | Tele 15m / Wide 0.1m | Tele 10m / Wide 0.1m | Tele 6m / Wide 0.1m | 30m |
Full specifications — available models(在售机型完整规格)
S50 Pro (Available / 在售)
- Aperture: Tele 50mm (f/5.2), Wide 3.4mm (f/1.75)
- Sensor: Tele 1/1.2" 2.9µm (8.3MP), Wide 1/2" 1.6µm (8.3MP)
- Resolution: Tele 2160×3840, Wide 2160×3840 (both 4K UHD)
- Field of View: Tele 2.8°, Wide 63° (portrait)
- Focal Length: Tele 260mm, Wide 6mm (equiv. tele 880mm / wide 35mm)
- Optical: 4-element apochromatic lens with ED glass
- Working Distance: Tele 15m–∞, Wide 0.1m–∞
- Filters: UV/IR-Cut (tele+wide), Dual-Band (tele only), Dark (tele only); external magnetic solar filter
- Storage: 128GB eMMC (~100GB usable); Battery: 10000mAh, up to 9h (ZWO lab data); Power: Type-C, supports DC 5V/3A or 12V/3A
- Transmission: Wi-Fi (5G/2.4G) / USB-C / Bluetooth; Wi-Fi effective range ≤10m, Bluetooth ≤5m
- Mount: Alt-azimuth mount (supports equatorial mode); speed ratio 1X–1440X; mechanical zero reset
- Image/Video formats: JPEG/FITS, MP4/AVI
- Base interface: 3/8-16
- Operating temperature: -10°C–40°C; Charging temperature: 0°C–40°C
- Weight: 2.8kg (main unit); Size: 140×149×268mm (folded)
- Pro features: DSO mosaic stitching (up to 8K), Milky Way panorama, landscape freeze, constellation recognition, Plan mode, AI Assistant, remote control, open expansion
- Milky Way star-trail shooting: Supported
- NFC: Supported
S30 Pro (Available / 在售)
- Aperture: Tele 30mm (F/5.3), Wide 3.4mm (F/1.75)
- Sensor: Tele IMX585 (1/1.2" 8.3MP), Wide IMX586 (1/2" 8.3MP)
- Field of View: Tele 4.6°, Wide 63°
- Focal Length: Tele 160mm, Wide 6mm
- Working Distance: Tele 10m–∞, Wide 0.1m–∞
- Filters: UV/IR-Cut, Duo-Band (OIII 30nm/Hα 20nm), Dark; external magnetic solar filter
- Storage: 128GB eMMC; Battery: 6000mAh (6h); Power: Type-C 5V/3A
- Weight: 1.65kg; Size: 140×80×210mm
- NFC: Supported
Key differences(核心区别)
- Aperture / light sensitivity(口径与感光能力): S50 Pro (50mm) collects about 3× the light of S30 Pro (30mm), revealing fainter deep-sky objects faster. S30 Pro is lighter and more portable.
- Field of view(视场): S30 Pro has a much wider telephoto field of view (4.6°) than S50 Pro (2.8°), better for wide nebulae and fast framing.
- Battery & storage(续航与存储): S50 Pro has the largest battery (10000mAh / 9h) and full pro features; S30 Pro uses 6000mAh but is more compact.
- Pro workflow(专业功能): Only S50 Pro adds mosaic/panorama, landscape freeze, constellation recognition, Plan mode, AI Assistant and remote control. S30 Pro is the lighter, more portable 4K option.
Which to choose(怎么选)
- S30 Pro — portable 4K: 1.65kg, 30mm aperture, 4K dual-lens (IMX585/IMX586), 128GB, 140×80×210mm. Great for travel and wide-field shooting where weight matters.
- S50 Pro — high-performance 4K: 50mm aperture for stronger light sensitivity, biggest battery (10000mAh) and full pro features (mosaic, panorama, AI Assistant, remote control). Best for serious deep-sky imaging.
Where to buy
We don't quote prices in this article, because they change with region, currency and promotions. Please use the official product page for your region.
| Region | Official store | Seestar S30 Pro | Seestar S50 Pro |
| United States | us.seestar.com | Open product page | Open product page |
| European Union | eu.seestar.com | Open product page | Open product page |
| All other regions — UK, Middle East, Asia-Pacific, Latin America, Africa | www.seestar.com | Open product page | Open product page |
Discontinued models — full specifications(已下架机型完整规格)
Note: The Seestar S30 and S50 have been discontinued and are no longer for sale. If you are looking for a replacement, the S30 Pro is the successor to the S30, and the S50 Pro is the successor to the S50. Specifications below are kept only for existing owners' reference.
注意:Seestar S30 与 S50 已下架,不再销售。 如需换代,S30 Pro 为 S30 的升级型号,S50 Pro 为 S50 的升级型号。以下规格仅供已购用户参考。
S30 (Discontinued / 已下架)
- Aperture: Tele 30mm (F/5), Wide 4.13mm (F/3.5)
- Sensor: Tele IMX662; dedicated wide-angle sensor
- Resolution: Tele 1080×1920, Wide 1920×1080
- Field of View: Tele 2.46°, Wide 23.2°
- Focal Length: 150mm
- Optical: 3-element apochromatic lens with ED glass
- Working Distance: 6m–∞
- Storage: 64GB eMMC; Battery: 6000mAh (6h); Power: Type-C 5V/3A
- Weight: 1.65kg; Size: 210×140×80mm
S50 (Discontinued / 已下架)
- Aperture: 50mm (F/5)
- Sensor: IMX462 (1/2.8" 2MP), no wide-angle
- Resolution: 1080×1920
- Field of View: 1.46°
- Focal Length: 250mm
- Working Distance: 30m–∞
- Weight: 2.5kg; Size: 142.5×130×257mm
Specifications are subject to change; always confirm on the product page before purchase.
规格可能更新,购买前请以产品页为准。
